Re: 309DPS and Gyro
why are you using a pmix? Why don't you just assign the gain control to the retract switch in the function menu? Then use the ATV of Aux1 to set the gain desired.
Patrick. [/B][/QUOTE]
Hi Patrick,
That's a good idea. I was using the P-mix in order to be able to switch it off in case I did not like the settings.
