RE: Himaxx 2812-0650 will it pull U-Can-Do Flight Flex??
If you want to use the cowl you will find that it is too high when mounted to the stock mount stick. My concern was that it raised the thrust line higher than the geared motor setup. Don't know if that makes a difference. I figured that was where they had it so thats what I would do. Joe
