RE: Twist servo question
It's not likely that the servo "glitching" you refer to is a servo problem, more likely something else. On my Twist maiden flight I was getting some erratic responses. I had the antenna inside the fuse in a tube, so I took it out, extended it outside the fuse, and that solved my glitch problem. Look to your set up to see what might be causing yours. Good luck.
