ORIGINAL: RCIGN1
..I guarantee I could make the hole large enough to flow more fuel and richen up the mixture...I also think a WT499 from a Glow G23 would do just that, it has large enough fuel passages to flow at least twice the amount of gasoline needed for the G26, so much so that it also works with methanol with no other changes...
Ralph, you don't know how hard I had to bit my tongue to keep from mentioning your name to Brian when he said they had sent some of the bad carbs out to some "carb specialist" and they couldn't do anything with them.
I even thought about drilling out the seat on the high side a .001 inch, but was afraid the needle taper would be too small then.
