RE: My first startup fire
I couldn't tell by reading your first post but is the motor primed, fuel in the line to the cowl when the sequence is started or is it having to pump from the pump to the engine during the start sequence? Is it aborting the start on its self or are you doing it? If you are stopping it, try letting it run thru itself if you are on a test stand.
