RE: NEW yaks at the Docs
Hi RTK
When you d/loaded the yak from the Docs you will find its 2 folders before you put the yak folder in the aircraft directory open the folder there you will find the folder you need, take it out of the first folder click on yes to all and thats the folder you put into the aircraft directory,then delete the first folder as the first folder is only a carrying folder.
NOTE: Some d/loads come down as one folder and some come down as 2 folders it pays to check.
OH and you may find a couple of files in the first folder that have to go in the second folder either way so long as youve got all the files in one folder.
Hope this helps
Regards Dave.
