RE: extreme aircraft cap 232
Has anyone had any problems setting up the throws for this aircraft?
I am using the control horns that came with the kit, but can't seem to get enough throw for the maximums on the elevator and the ailerons.
I am nearly an inch short on the elevator and ½ inch on the ailerons. I am also only able to get minimum on the rudder, but that’s because I am using the bar control arm that came with the Du-Bro heavy duty Pull-Pull.
Any suggestions?
