Throttle Spring Removal
I've just recieved a new Taurus TS-72 gas engine. The spring that returns the throttle to idle is very stiff and will make the throttle servo work hard at any setting above idle. I assume the main reason for this spring is safety. Do most of you leave this spring on, or cut it out. Thanks for any input.
