spring in carb
If you want to eliminate the return spring force do NOT cut it out! They are required to keep the butterfly in the correct place. Just unhook the little hooked portion (so the spring is still there but not "hooked up") or trim the hooked end off. The spring will then still press outwards but not provide any return force.
Andrew Coholic
