RCU Forums - View Single Post - 3 Channel Flying?
Old 04-21-2005 | 07:41 PM
Gollywock
Default RE: 3 Channel Flying?
Three channel flying is every bit as easy four. You simply add in a little elevator to keep the nose up during a turn. What causes the airplane to bank during a rudder only turn is that as you apply rudder, the outside wing begins to skid around the inside wing, therefore generating more lift on the outside. As soon as you enter a turn, give it elevator, and the turn will be as coorinated as with four channel. Jim
