RE: Insight build...another wood roach.
I mounted the motor (rear lugs only) to the iso mount and then setup a washer/spacer to allow clearance between the spinner backplate and F-1 (nose former). I tack glued F-1 to the back of the spacer/washer set and bolted it to the motor. I then carefully pulled in the fuse sides and glued them to the sides of F-1.
