RCU Forums - View Single Post - HInges
Thread: HInges
Old 04-21-2005 | 11:04 PM
mstroh3961's Avatar
mstroh3961
Default RE: HInges
You should get a syringe and fill it with poly glue. Deflect the surface and slide the needle beside the hinge point tell you pass the barbs. dispense the glue as you slowly withdraw the needle. do this on both sides of the hinge, above and below as well. The poly/gorilla glue foams as it cures so it should fill in around the barbs.
Good luck!
