Equalizer II problems
Back in Feb I purchased 2 Equalizer II's and I set them up as per manual with JR 8231's, 2 per wing. When it came time for maiden a couple weeks ago I was setting everything up at the field and doing preflight checks I noticed when I moved the aileron sticks slowly I got a very jittery movement on each aileron, they were stepping badly on each movement. I was also getting very short range checks and then I had 1 Eq that lost the setup to the second servo. I pulled the Eq's out and put a spare reciever that had Aux channel 1 for the 2nd servo (running dual rx's) and at that moment I had excellent range check again. The 8231's also ran much smoother and I ended up putting on a few good flights that day.
Please advise what I should do because at this moment I do not trust using these in any of my planes.
Kelvin Buck.
