RE: replace CA hinges
That is a great article that I've seen before.. although I didn't follow the remove the covering around the hinge advice on one plane although I did drill the hole... seemed fine but later (after a crash unrelated to elevator) I was able to pull the hinges right out easily... CA hadn't wicked to the back deep inside, it was clean and doing nothing!
