ORIGINAL: preivers
Sent you a PM.
I responded
ORIGINAL: DarZeelon
If these back-plate mounts replace the original backplate
I don't think so. From the third picture you see the original back plate in place. And there wouldn't be a hole in th center, otherwise you will se the crankshaft through it
I don't know how long original screws are. If more than 15mm ther emay be OK, but if shorter I wouldn't use them. The longer the better as in crash they would spread the load along the crank case. I would rather have firewall or engine case broken than crankcase. This engine cost more than twice of the planes I am going to put it on.
Now I need this mount fast. If I don't get it soon, I will have to make it myself.
RysiuM
