gjeffers, Great job!!! My last two have weighed exactly 5lbs 14ozs. That's the magic number. I have my latest one with a CG at 5 3/4". But anywhere between 4 and 6 works great. The beauty of this plane is the CG is very flexible. My first two I had trouble getting under 6 lbs but mostly I just changed the wheels and went to a slightly smaller battery to get to 5/14. Mine flies great at that weight. I worried about your power. Do you think you'll have enough? Good luck on your maiden. By the way: prop glue?
Thanks.
Barry
