As noted..the T-34 is complete with "markings" and also slight weathering which is nice...The Tank has a Strong Turret Rotation that many Tankers have begun to try to adapt to Tamiya Tanks as it is very strong and seems to be better than the Tamiya Rotation unit...However other than this the T-34 will basically be a "shell" for us to convert to Tamiya Electronics...Multifunction and DMD unit with Tamiya Battle Unit to participate in Combat....txtanker has already converted his with Tamiya Pershing electronics to Full Function Combat ready status...txtanker can you post pics and give us a run down on the conversion??
In this last pic can you see the Tiger 1 in the Background...THis will give you an idea of the size difference between the two..as they are both 1/16 scale..[8D]
