Hello zx6rg2
Can you describe the fuel system you have. The error light your seeing indicates a possible problem with your fuel system.
Sincerely,
Ed
ORIGINAL: zx6rg2
hi my simjet 3000 will not start ,it was fine for the 4or5 test run and only had 3 flights in the plane and the last one flamed out .the engine starts on gas then shuts down leaving a red light on ,when i do get it to run it run for a very sort time at idal them flames out with lots of smoke out the back
