RCU Forums - View Single Post - Adjustable diff seting up
Old 04-23-2005 | 11:30 AM
mrfisse
Default RE: Adjustable diff seting up
You bought a new diff or you just want to know ? I recently bought the alloy differential and its the same diff as the adjustable one. Exept for the shell. If you have the standard alloy diff shell you cant adjust it, only poke things into the hole in the diff housing
Otherwise there is supposed to go some kinda screw through that hole that you adjust from the shell.
http://www.buildersedge.net/fgcat2004/Html/154.htm
