RCU Forums - View Single Post - Composite ARF Impact
Old 04-23-2005 | 01:16 PM
  #554
Andy P.'s Avatar
Andy P.
Default RE: Impact
Hi Guy's,
Thought I'd share these with you. After an engine cut (my fault entirely, forgot to adjust throttle trim in ST1) I have had to fit some new gear to the Impact. I've gone for the Bolly F3a Wide with matching spats. I got them through Elation Models here in the UK (check www.elationmodels.co.uk). I had to trim the fixing plate a little in width on each half but other than that they went together quite well. They do provide a wider track than the carf u/c and the legs are solid carbon strand instead of carbon cloth over foam.
Regards,
Andy.
ID:	261883   Click image for larger version
ID:	261884   Click image for larger version
