RE: starting up an .049 engine
The startup sequence should be:
1 open needle valve 3-3 1/2 turns
2 fuel tank with 15-35% nitro fuel
3 prime cylinder with a drop or two of fuel
4 attach 1.5 volt battery to glowhead
5 turn engine over with spring/hand/starter
6 fine tune needle valve till the engine is screaming then back of 1/8 turn.
But I'm kind of with Flyingrog here, maybe you need to move the grass - dunno. I mean it sounds like to engine is running until YOU loose control of the model - yes/no?
HTH - Steve B.
