RCU Forums - View Single Post - Precedent Hi-Boy
Old 04-24-2005 | 05:03 AM
Beige's Avatar
Beige
Default RE: Precedent Hi-Boy
OK,
If you look at your engines manual there should be an "idle speed" adjustment, this will be small screw or something that limits the travel of the carb barrel,
be sure you've got the right screw and slowly turn it until the carb can just close fully
You can also stop the engine by blocking the air intake, or one of the fuel tubes, but with a prop spinning away at the front this isn't the safest way to go
