RCU Forums - View Single Post - Side mounting engines
Old 04-24-2005 | 05:41 PM
bobbykokinos
Default RE: Side mounting engines
Thanks for the advice guys. I'll definantly go with a side mounted engine. Id rather be up flying than fiddle farting around with the engine all of the time trying to get it to run right.
This may be a dumb, trival question BUT when I do side mounting, I simply flip the engine mounts 90 degress and make sure the prop is still in the same place as it would be if the engine is inverted, correct??
