RCU Forums - View Single Post - right Thrust?
Thread: right Thrust?
Old 10-16-2002 | 06:41 PM
n64uw
Default right Thrust?
Thanks folks for the input on where to purchase shims and alternative mounting techniques. I understand that Ernst is no longer in business. As to my current project which is a Pilatus Porter 94" ARF the sanding option is a bit difficult, although I will use it in future kits that I build.
So, I am going to try molding a shim to fit the backplate area of the BGX-1 from epoxy, graphite, and fibres unless someone talks me out of it. I have been advised by others that using washers on larger engines places the mount in jeopardy...so, building a tapered shim is suggested...(per ken laski).
Stewart Tittle
