RCU Forums - View Single Post - St 2300 ......
Thread: St 2300 ......
Old 01-24-2002 | 07:27 PM
pe reivers
Default Re: St 2300 ......
Originally posted by Goggles
How many of you have had problems with the Super Tiger 2300?
What problems did you have and how did you fix it?
Those of you with out any problems, what is your configuration...What prop, size & location of fuel tank, how much cooling area, etc.
I've just fired up my 2300 and need to know what to expect for performance and problems.
Thank you for your help.
Kelvin.
I have had bad running with my ST2300 because of the "improved" Supertigre carb, and after discussions with Ted Bloom, solved all problems on the go. The solutions are documented on my web page. http://www.reivers.myweb.nl
Also available are drawings of the required modifications, and CAD sections on a Mousse can motor mount for the engine.
Treat it well. It is the best large glow engine I ever saw, and it has the Italian material quality go side by side with the Italian temper! Do be careful not to break the ring when you dis-assemble the engine. You might not find a replacement.
