RCU Forums - View Single Post - Repairing Sheeting
Old 04-25-2005 | 01:26 PM
bruce88123
Default RE: Repairing Sheeting
Skynyrd Man-That would depend on if you had the correct color of duct tape. Have you seen the guy on TV that does the duct tape show? It is one crazy show. My brother watches it all of the time. I have not seen it down here but he lives in central Michigan area near Grayling. It is a hit there.
Chad- the wood glues(yellow) like Tite Bond II take a while longer to dry but make a strong joint and sand easily. Can be gotten at Home Depot and the like too I believe. Since you are not in a hurry (or shouldn't be) you could use it in some places on 4*. Put a small drop of ca to tack a joint and then go back an reinforce with the wood glue before going to bed. By morning all will be dry. As with all glues do not over apply. Can brush a real small amount into corners with a small artist brush and the brush will rinse out with water and be clean and dry in the morning too.
http://www2.towerhobbies.com/cgi-bin...4&I=LXHS59&P=K
This is what I use in many cases
