RCU Forums - View Single Post - Pull starter probem!!
Old 04-25-2005 | 01:29 PM
snowbl!nd's Avatar
snowbl!nd
Default RE: Pull starter probem!!
ORIGINAL: r40
thanks for the help, i was kinda thinking about what you said snownl!nd. i plan on trying this, i think that if i can controll my anger long enough, i just might be able to do this.
You will probably need someone to help you, it takes 2 hands to wrap the cord and another person to hold the "internals" of the pull start, to stop the spring pulling the cord back in and undoing all you hard work. Bear in mind that you do NOT need to remove the spring etc, just remove the entire pullstart assembly from the engine in one piece (use a knife or something similar to get both the "inner" part and the pullstart housing in one go). Once you get the hang of doing this it seems incredibly easy.
