Find a local club with an instructor, he will be able to show you what is available in your country. It probably is not the same as over here. You do not want a plane the is a SCALE replica of ANYTHING. It just doesn't work out well in modeling for a first plane. I won't get into the reasons here, they are lengthy. You really NEED a high-wing trainer aircraft for your first plane that will fly fairly slow for landings but will still have maneuverability to a degree.There are many of these to choose from in the US and I'm sure over there also. As I said before, Find a local club. You should be able to locate one through your local modeling society or local hobby shop.
I wish you luck on this and welcome you to the hobby.
