RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-25-2005 | 03:00 PM
  #1883
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
CeeGee... It'll work, you just have to diddle with it some what.. But once you
have it setup... You'll never go back:-)... You can do so much with a computer
radio, and in return it'll make a few things a lot eaiser!!!... Plus as Barry said
once you get one plane setup you can just copy that info for your next plane
setup, Then you'll forget how you did it, but you can continue adding planes
to your radio:-)
Well my YS is not running great on the ground, But she does the job in the
air... Got 4 flights this morning and she ran great, just does not like to idle
to long:-(... Guy's at the field asked me why was I running to get my plane
after I put my radio on the gate radio stand, I told them I'm getting tired
using all that fuel just on the table, so I have to hurry to get it up:-).. I
guess the AZ heat is getting to the YS, But it is idleing better with the cowl
off.... She flat spins great now, Hovering is lacking pull out in this less dense
HOT air:-( She still floats good, but not as good as in the winter..... I'm
thinking of switching props to get a little more bite...
