Balance question
I have been busy reading the links that you guys gave me
regarding the Imac rules and Sequence.
I have also been playing around with the trim charts and I have a question
on CG.
My Wild Hare Edge is balanced right at 3.75" back from the leading edge.
The specs. say 3.5 to 4 inches.... When I roll the plane inverted it flies level with no
input. On a 45 degree up-line if I roll inverted it seems like it almost wants
to climb, but stays pretty much on heading.
The trim charts I have seen do not address this, only if it climbs or falls....
Is it down to personal preference at this point, or should the plane
slowly arc down in a 45 degree up-line?
stays on course!QUOT!
