RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-25-2005 | 04:31 PM
  #1885
SPUD37's Avatar
SPUD37
Default RE: U-Can-Do 3d 46?
Hey Cee Gee, Spud here I have mine set up that way and it works great . You'll like it. The reason chan.5 doesn't work is because it is just a on off switch activation. Chan 2&6 are used because of the flaperon relationship. You should be able to turn that feature on and be set as far as your ail & flap/spoil functions covered. Also check out your 2to6 & 6to2 functions out for tight loops. Hope some of this helps. Withthe 6to2 funct. you can zero out the chan2 and with a flip of a switch you'll deploy your spoil.
SPUD37 out
