RCU Forums - View Single Post - Cen st2
Thread: Cen st2
Old 04-25-2005 | 04:36 PM
Jester79
Default RE: Cen st2
If you go 2wd I suggest switching it over to a slipper clutch, and changing the front diff case to a bulkhead. to change it over correctly it requires some parts and time. It takes more than just a center drive shaft removal, if you do that it puts to much power directly to the wheels to quickly hence the drifting/spinning out. The slipper clutch makes the power more controlable.
