RE: Pull starter probem!!
Before you go to the hassle of pulling it apart... loosen the screws (not remove them) and slide the pull-start around. Sometimes when you put the assembled pull-start back on they can bind. If the cord retracts when you loosen the screws that's usally the issue. Then just periodically give a slow short pull to make sure it doesn't try to bind again as you tighten it back up.
