RE: First flight on tower trainer and balance issues
Ok, the manual says that the CG needs to be 3.5" behind the leading edge. With the weight removed I can't hold it there without it slipping off my fingers because it is too nose heavy. if I move my fingers 1" forward then it will balance with the nose about 3" down from the tail.
I'll reposition my radio and see if I can make up some of this, but in the end I am pretty sure I'll need weight. It isn't just a little nose down it's WAY heavier on the front than rear.
So just to be clear, what I'm looking for is for the plane to point a little nose down but balance when I hold it up 3.5" from the leading edge where the manual says the CG should be.
schu
