RCU Forums - View Single Post - monokote seam over open areas
Old 10-03-2002 | 03:42 AM
Giant Scale
Default monokote seam over open areas
Acetone or trim solvent will also work instead of using the iron. I usually use a 3/8" to 1/2" overlap to make sure the seam won't pull apart when you shrink the monokote. Remember to layer your dark colors over your light colors.
