RCU Forums - View Single Post - HELP! My engine won't run!
Old 09-28-2002 | 02:19 PM
amcross
Default HELP! My engine won't run!
Hi, KL! Happy to assist. Yes, please bench break in. It'll likely help a lot.
Given the same problems with two new engines in the same setup, I'd really take a look at the muffler. If the backpressure isn't enough, that'd explain the erratic running. Again see if you can find a way to use the stock exhaust, even if only for a test run on the ground, to rule that possible problem out.
