RE: Engine gets really hot
GCB is closest to correct for a tractor pull setup. Before you go off and run a diesel on a tractor, first learn how to run it on a propeller and the fuel it was made to run on. As for making your own head that only makes the learning problem worse as things are never as simple as one assumes if one does not no enough about the details. When you make a Chinese copy without the Chinaman there may be problems.
