RCKen,
Sounds like a good plan, I'll work on the CG issue first, then the control surfaces.
Here is a picture of how it looks with the added weight and the radio equipment moved as far back as possible:
The plane is pointed down, but only slightly. Should I run with that or reduce the weight a little?
schu
