Robart Retracts - again
Robin, if you have a metal tank, you do have a metal air tank don't you? You can run 100psi or even a little over. 80 is about the bottom of the preasure range to operate these. If you have a plastic tank get rid of it as I have seen what happens when out in the hot sun. Blows a fuse into very tiny pieces. Don
