RCU Forums - View Single Post - which battery pack???
Old 04-27-2005 | 05:05 PM
exeter_acres's Avatar
exeter_acres
Default RE: which battery pack???
depends on the plane I suppose....and I am not sure the exact ratings of that motor
the 8c might work.... run the numbers through Motocalc or pick up a Whatts up (or similar) I didn't want to either, but I'm glad I did....
I use Thunderpower 1320 3S1P packs with good luck and a polyquest 1500 pack (the polyquest is quite a bit bigger but weighs about the same..)
I use this in 3dfaomy style planes.....
