RCU Forums - View Single Post - ailerons in wings, suggestions?
Old 04-28-2005 | 10:15 AM
h-ray-RCA's Avatar
h-ray-RCA
Default ailerons in wings, suggestions?
Hi guys,
This is my first time doing them, any pointers are welcome. The Antic is set up for bellcranks and pushrods circa 1970ish but I was not going to do that so I roughed this out.
-Do I need to run a tube inside the wing for the servo leads or is it ok to just let them flop around? Flopping around might induce the connector to disengage, strain the wire, etc. Adding the tube will make it easier to rethread the leads should I have to remove the wires someday. But it also adds weight, and will look funny when you look through the fabric in the sunlight.
-I'll reopen the debate about cutting off the leads close to the servo and resoldering on new single length extensions. Good or Bad?
-If you don't do that then how do you keep the extensions from seperating from the lead? It will be in an electric Antic so there should not be a big problem with vibration.
Steve
