RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-28-2005 | 02:21 PM
  #1931
rclement's Avatar
rclement
Default RE: U-Can-Do 3d 46?
Hey Spud, We had lots of smokers on board back then. Worst thing was that we didn't have an oxygen generator on board so eventually we would get low on the amount of oxygen we could bleed out from the banks so we would have to light what they called "oxygen candles" The "candles" would burn down and add oxygent to the air but usually lower amounts than normal. You could tell the oxygen level was too low when peoples cigarettes would go out if they hadn't taken a puff on them for a minute or so. True story.
Hey Barry, I got my "spoilerons" set up. I just deleted the settings I had and started over using a section of the Futaba FAQ page. It works. Only thing is I'm not sure of is what direction the elevators are suppose to go when the ailerons go up. When the ailerons go up are the elevators supposed to go up or down?
