RCU Forums - View Single Post - How do I hover?
Thread: How do I hover?
Old 09-29-2002 | 06:41 AM
Kanain's Avatar
Kanain
Default How do I hover?
bgc22 -
Do u want to hover or torque roll?
In either case, make sure your radio is set on high rates if you have dual rates (except ailerons for a torque roll - some guys use aileron to assist in a constant roll rate, but this is not an actual torque roll).
Mount enough power on the firewall to swing a large-diameter prop giving the most thrust. Also set the CG a little aft of the recommended.
Pull the aircraft to the vertical while slowing it down. Practice vertical lines until you have them clean. If you are not using gyros or mixing on a computer radio, make sure you add in some rudder on the initial pull because the aircraft nose will tend to walk on the pull.
Let the aircraft slow until it falls back slightly - this is the "zone". The aircraft has to be in a complete vertical with the tail under the nose.
At this point, torque will take over and start to roll the aircraft in a R/C modeler "torque roll". The full scale Torque Roll is a rolling vertical with a controlled, maintained roll-rate as the aircraft moves back down (backward) on the vertical line. For our purpose, ailerons will do you no good. Control the vertical with elevator and rudder. Keep the tail under the nose. This requires small movements of each surface, but you will need high rates in case the tail wanders a lot. To get used to the control inputs, move one input at a time (rudder, elevator). The torquing is accomplished by the engine torque and the rate can be controlled by altitude (power). If the aircraft is rolling slow, reduce throttle and let it settle through the prop-wash a little more. To slow things down, add power and climb slightly.
To hover, entry is the same but rudder and elevator movements are more exaggerated to suspend the roll. As I stated earlier, ailerons are pretty ineffective at this point because of the low or non-existant forward speed. However, you can burp the throttle to achieve some aileron effectiveness in both maneuvers.
And as jnjacksn said:
P R A C T I C E
P R A C T I C E
P R A C T I C E
Hope this helps - good flying.
