I think it's a good practice to always try to have all the radio gear setup the way you want it before doing it with the TX, that way you'll have a bigger available adjustment range with the TX in case you change something. It works for me
Try adjusting the throttle curve using the outer hole and changing the servo arm position, if you combine it with an adjustable arm you'll get it just the way you want it
good luck
