RCU Forums - View Single Post - Insight build...another wood roach.
Old 04-28-2005 | 11:01 PM
  #84
flyintexan's Avatar
flyintexan
Default RE: Insight build...another wood roach.
Been too busy to really work on the plane alot...however I have been sanding and adding filler where needed. I have added fillets on all the inside corners of the fuse and it is starting to look better and better.
On the wings, I have sanded in the trailing edge cap, the ailerons are capped and rough sanded. It is now time to glue on the root ribs.
ID:	264431   Click image for larger version
ID:	264432   Click image for larger version
ID:	264433   Click image for larger version
