RE: Needle Valve Setting YS .91AC
It could be that the needle valve seat is worn out, along with the needle itself.
If you screw the needle in all the way until it stops, does the needle valve body bottom out on the hex portion of the spray bar? If it does, it is a sure sign that the NV assembly is worn out.
