RCU Forums - View Single Post - EXCEL FUELER: mounting & use
Old 04-29-2005 | 08:44 AM
greenpilot
Default EXCEL FUELER: mounting & use
Need some help with where to mount an Excel Fueler on a taylorcraft. Does it need to be in line with the carb? Can it be mounted in the fuse, leaving the cowl easier to remove? If on the cowl, there is a perfect size hole in the front of the cowl, near the spinner hole.
Any reason why it couldn't be mounted there and thus avoiding anymore cutting of the cowl?
Also, can the fuel be emptied from the tank with this system? I've already bought the fueler! Thanks
