RCU Forums - View Single Post - Differential Ailerons on Pattern Airplanes
Old 04-29-2005 | 08:55 AM
Bob Pastorello's Avatar
Bob Pastorello
My Feedback: (198)
Default RE: Differential Ailerons on Pattern Airplanes
I always thought it had to do with the fact that lift coefficients were changed when the aileron deflected, meaning the downward moving aileron INCREASED lift, and the upward moving increased DRAG, thus causing the yaw. ALthough most pattern airplanes these day have the wing location on the fuse correct to offset this, years ago, it was a real problem (lower wing placement on fuse increases need for differential)
BUT I could be wrong, here....
