RE: Differential Ailerons on Pattern Airplanes
Part of the problem is the design of the airplane. If everything was set at zero that won't reduce the need for differential. The shape of the wings in relation to the ailerons and the shape of the ailerons are the main factors, but also the tail moments and fuse design.
