RCU Forums - View Single Post - Best 3D plane for OS 46fx
Old 04-29-2005 | 12:23 PM
Shogun
Default RE: Best 3D plane for OS 46fx
I guess it's not available, yet. Sorry about thet, I have not looked at their site in a while and thought I read on here that it was available a while back.
I'm not sure if it's still available but Extreme Flight's Edge is very similar and is an ARF so that might be something worth exploring. My only complaint about the ARF profiles is that they are sorta tender and will snap in half right behind the wing in the event of a nose in. Th OMP Edge 540 profile kit has a peice of 1/4 x 1/4 spruce that runs the length of the fuse on the bottom that really stiffens the plane up and makes it very resistant to snapping in two. I have put mine in 3 times and the fuse has stayed intact, wings usually needed some work but that was pretty easy.
If your not opposed to building and have a few kits to your credit don't overlook the OMP kit. I think mine took about a week of evenings from the box arriving to having it in the air, really simple to build and a lot tougher than any ARF I have seen. If by some chance you do decide to try your hand at building one of these in the future do yourself a favor and trace the ribs on card stock so you have a pattern to make new one's with should you have to. There are six ribs per wing and those shapes are not on the plans.
